1. AC Question's Avatar
    Hi, i a rooting my Device Samsung Galaxy Grand 2
    the whole process is done.
    on mobile it display Downloading...... do not turn off target
    what should i do???????
    plzzz tell me......
    09-14-2014 01:55 PM
  2. srkmagnus's Avatar
    plzzz tell me......
    It looks like you may have been in Download Mode? If so, you'll need to use Odin to install the appropriate files for whatever it is you are trying to install.
    If you rooted, then reboot - long press power or remove battery and reinsert then start.
    09-14-2014 02:26 PM
  1. Considering getting rid of my one m8
    By chris2707 in forum HTC One M8
    Last Post: 09-19-2014, 05:18 PM
  2. Replies: 3
    Last Post: 09-17-2014, 03:57 AM
  3. Replies: 1
    Last Post: 09-14-2014, 02:32 PM
  4. SD Card Issue in my Galaxy s4 mini
    Last Post: 09-14-2014, 11:26 AM
  5. Samsung Galaxy s5 Needs To Be Reset But It Is Dead
    Last Post: 09-14-2014, 11:22 AM
