1. AC Question's Avatar
    Im a newb to android products but i figure out how to root my nexus 7 tablet. When i went update it went into recovery mode. Then when i went to restart it tells me "no system os" i also cant connect it to my chromebook so im not sure how to get it operating again ... I would like to get it back to factory if possible
    Some help would be greatly appreciated
    09-14-2014 09:11 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which Nexus 7 do you have, the 1st or 2nd gen? May I ask why you want to root it, if you're brand new to Android? I would not recommend rooting to complete novices, because you can easily do the wrong thing, and end up with a very sleek and shiny paperweight. It sounds like that may be what happened.
    If you have a 1st gen Nexus 7, try to restore the factory image by reading this thread: [GUIDE] Nexus 7 - Factory Image Restore
    Android devices don't connect to Chromebooks (at least, not yet--MTP mounting support is supposedly coming soon).
    09-15-2014 12:15 AM
  3. Blair Gavin's Avatar
    I have the 2nd generation. I anted to root to get a specific app that maximize the screen space. So I read information and figured it out not knowing everything about rooting. Then went to update thinking nothing would happen and thats when i got the no system os message. Also when i plug in tablet to the computer nothing shows up on the computer.
    09-15-2014 10:28 AM
  4. Blair Gavin's Avatar
    any thoughts on my recent post??
    10-07-2014 04:41 PM
  1. 1st Time Poster With A Couple of Questions of Features I would like your help in getting
    By shimsha2005 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 09-20-2014, 01:46 PM
  2. Kepard VPN Issues?
    By blackdogAC in forum LG G3
    Last Post: 09-15-2014, 09:43 PM
  3. Help with Acer Iconia A500 Tablet's broken power button
    By daman2989 in forum Ask a Question
    Last Post: 09-15-2014, 04:50 AM
  4. Earbud recognition issue
    Last Post: 09-15-2014, 12:22 AM
  5. Nexus reliability
    Last Post: 09-14-2014, 09:30 PM
