1. AC Question's Avatar
    The High accuracy and Device only modes are grayed out on my device, with the Battery saving radio button the only option. I've climbed through the various setting on my device, and I cannot find a way to bring back the ability to choose one of the other Location modes. What gives? Many thanks for any help that is offered.
    Harris
    09-16-2014 10:02 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! That would suggest there's a specific problem with the GPS radio, since High Accuracy and Device Only both require GPS. Which device do you have? Does a reboot change anything?
    09-16-2014 10:37 AM
  1. Why is my phone draining on airplane mode?
    By Javier P in forum Moto G (2013)
    Last Post: 11-16-2014, 11:50 PM
  2. Looking to install an custom ROM on my GSM Note 3
    By cbialob1 in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 10-04-2014, 10:20 PM
  3. Loosing 25% power when switched off in 6 hrs
    By smartjais in forum Samsung Galaxy Note 3
    Last Post: 09-16-2014, 04:59 PM
  4. How do I get files off of my phone with my screen busted?
    By zoeph2011 in forum Samsung Galaxy S3
    Last Post: 09-16-2014, 03:40 PM
  5. Total Meltdown - Screen busted need to pull files
    Last Post: 09-16-2014, 10:30 AM
