1. AC Question's Avatar
    I've tried everything and it just won't work
    09-16-2014 11:48 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! So does the wi-fi just not turn on? When you go to Settings>Wi-Fi, is the switch greyed out, or does it automatically turn back off after you try to turn it back on? Can you tell us what you've tried? If you say you've tried everything, it's less likely that people will respond, because they'll assume you've already tried what they may suggest.
    09-16-2014 01:15 PM
  3. bholeoliver's Avatar
    The wifi icon is grey and when I hit it on it doesn't even turn green, I have tried deleting the wpa supplicant and downloading a few wifi fixs and using odin to install them and none of them have worked, although deleting the wpa supplicant did work a few days ago but then I unrooted my phone but a day or so after doing so the wifi stopped working again and now that my phone is no longer rooted and can't delete the wpa supplicant again
    09-16-2014 04:49 PM
  1. LG Lucid 3 help please!
    By DWhitleyCA in forum Software Development and Hacking
    Last Post: 09-28-2014, 12:11 PM
  2. Replies: 5
    Last Post: 09-16-2014, 05:27 PM
  3. Replies: 1
    Last Post: 09-16-2014, 11:33 AM
  4. Phone Help!
    Last Post: 09-16-2014, 11:30 AM
  5. Acer Iconia Tab A700 Bootloop HELP!!
    By ausombabs in forum Acer Iconia A700
    Last Post: 09-16-2014, 11:13 AM
