1. AC Question's Avatar
    i am failing to send photos and video using my phone all the applications including whatsapp facebook and google talk are not responding . they just keep on loading even thenet is available .can not use wifie it can not even dectact where there is wifie
    09-17-2014 04:23 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! You're talking about the Nexus 4, right? Or the Galaxy S4?
    When you say "all the applications are not responding," do you mean just the ones for sending messages? Is your mobile data (3G/4G) on? Are you sure the wi-fi radio is turning on? Are you saying it can't connect to any wi-fi network?
    09-17-2014 12:19 PM
  1. Nexus S
    Last Post: 09-17-2014, 09:43 PM
  2. Can't Find my nexus 7 on PC
    Last Post: 09-17-2014, 12:14 PM
  3. Problem with SPlanner and Google Calendar
    By Unregistered in forum Ask a Question
    Last Post: 09-17-2014, 05:54 AM
  4. samsung s4 will only charge when turned off
    Last Post: 09-17-2014, 03:26 AM
  5. Replies: 1
    Last Post: 09-17-2014, 02:55 AM
