1. AC Question's Avatar
    Can anyone direct me to a feature on the Note 3 that would automatically insert a "1" (if one is not there) to make long distance calls when necessary? I don't want to have to put a 1 in front of every area code for each contact in my contact list.
    09-19-2014 04:45 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do you have to enter the 1 in front of the area code? I was under the impression that cellphone calls don't require the 1. I don't have to on T-Mobile.
    09-19-2014 04:54 PM
  3. KEVINHEAVEN's Avatar
    It may be a carrier issue. I am in Canada with Rogers as the carrier. However, I didn't have the problem with my old BlackBerry on Rogers. Strange!
    09-19-2014 05:04 PM
  4. B. Diddy's Avatar
    Have you called Rogers about it? Maybe they have a quick fix.
    09-19-2014 05:54 PM
  5. KEVINHEAVEN's Avatar
    Yes....tried Rogers......no luck there. They say it is a device issue and there must be a setting to adjust. I know BlackBerry had a such a setting to avoid putting "1" in front of your Contact numbers when dialing long distance.
    09-20-2014 05:44 AM
  6. B. Diddy's Avatar
    See if there is a Settings>Call>Auto Area Code menu, as mentioned in this guide (search the page for the word "prefix"). Device > Online Guide for Galaxy Note 3 > AllAboutGalaxyNote.com
    09-20-2014 03:07 PM
  1. Stuck in Boot loop and wont turn off
    By Rondell Ramdass in forum Samsung Galaxy S4 Google Edition
    Last Post: 08-06-2015, 10:00 PM
  2. Get emojis to play nice?
    By kcsamerica in forum General Help and How To
    Last Post: 09-21-2014, 11:08 PM
  3. Titanium backup or regular backup through recovery?
    By passion4tech in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 09-21-2014, 01:31 PM
  4. Moving from original Note to S4?
    By thoots in forum Samsung Galaxy S4
    Last Post: 09-20-2014, 12:39 AM
