1. LolloJberg's Avatar
    I just put in a new audiobook on my phone and it shows up as just 3 minutes long. If it's on play it can go past this point (It's 11 hours long) but if I paus it jumps back to 3 minutes.
    The file is an mp3 and if I play it in itunes it works just fine. I'm using MortPlayer when listening to my audiobooks but it's the same problem on the music player that comes with the phone. I own a Samsung S4 Mini and other books/files have worked just fine.
    Any idea what's going on?
    EDIT
    Just checked and when I drag and drop it to the phone the file says it's 11 hours long and when I diconnect, that's when it changes into 3 min, cause when I connect the phone to my computer (via USB) again it's down to 3 min.
    09-20-2014 01:03 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! How big is the file? Where are you copying the file to, the external microSD card or the internal storage? There might be a filesize limitation that is causing a problem, since FAT32 (the usual SD card format) limits files to 4 GB.
    09-20-2014 03:33 PM
  3. LolloJberg's Avatar
    It's bigget than 4, it's 6. I don't have an SD-card in it though. Not that I have put in at least?
    I'm copying it directly on to the phone as far as I know, into the music folder it holds. Is there a limit there too?
    09-20-2014 03:41 PM
  4. B. Diddy's Avatar
    Phones sometimes come with the external SD card installed. Go to Settings>Storage​--is there an external SD card listed there?
    09-20-2014 04:32 PM
  5. LolloJberg's Avatar
    Nope, nothing.
    So there shouldn't be a limit on the internal one?
    09-21-2014 02:08 AM
  6. B. Diddy's Avatar
    I'm not sure. I'm trying to figure out what the filesystem format for the S4's internal storage is. If it's also FAT32, then it would also have a 4 GB filesize limit. If it's another format like EXT4, then there should be no practical filesize limit. Trying to gather more info.
    09-21-2014 02:26 AM
  7. LolloJberg's Avatar
    Oh, sorry!
    Thank you so much for helping though!
    09-21-2014 02:43 AM
  8. Kevin OQuinn's Avatar
    Have you tried putting it in the root of the storage and not the music folder?
    09-21-2014 03:20 AM
  9. LolloJberg's Avatar
    Doesn't work either...
    09-21-2014 03:56 AM
  10. LolloJberg's Avatar
    I tried to split the file in two and then it works just fine. So it's probably the file limit that is the problem. Shame you have to do it that way though...
    09-21-2014 04:08 AM
  11. Golfdriver97's Avatar
    Perhaps a reformat of the card? Backup everything to your PC, then with the card in your phone, reformat it.
    09-21-2014 08:21 AM
  12. LolloJberg's Avatar
    As I said before, no card :/
    09-21-2014 08:39 AM
  13. Golfdriver97's Avatar
    Sorry...that's what happens when you post something literally a few seconds after waking up.
    Maybe a different player? PowerAmp has a free trial period, afterward it is a one time purchase of $4 or $5.
    09-21-2014 09:12 AM
  14. LolloJberg's Avatar
    It's okay
    It seems like the file itself is shortens down though. Not just in the apps. I tried the one you suggested though but still the same problem. I guess the only thing I can do is split the files :/
    09-21-2014 12:26 PM
  15. Golfdriver97's Avatar
    It's okay
    That might help. There might be a read error somewhere.
    09-21-2014 12:31 PM
  16. Rukbat's Avatar
    It's more like a "misunderstanding" error, I think - whoever created the audiobook didn't understand that a lot of storage media is going to have that 4GB filesize limitation, and that they should make a couple of volumes out of the book. Splitting the file is about the easiest way to fix it and, if split at a logically sensible point, doesn't cause a problem. (Unless it's James Joyce - then finding the end of a sentence may be difficult in only 6GB. Or Coe's "The Rotters Club", which has the longest sentence in the English language [about 70k in text - I have no idea how long that would be as an audio file when spoken].)
    B. Diddy and Golfdriver97 like this.
    09-21-2014 01:21 PM
  1. How to fix " camera failed error message " for Galaxy S5?
    By NAVEEN ELDOSE in forum Samsung Galaxy S5
    Last Post: 09-22-2014, 02:51 PM
  2. please help me to create database in android...
    By pravesh goel in forum Ask a Question
    Last Post: 09-20-2014, 07:50 PM
  3. Update installation trouble..help!
    By katiebushar in forum Ask a Question
    Last Post: 09-20-2014, 03:12 PM
  4. Help unbrick HTC desire
    By Donwise in forum Ask a Question
    Last Post: 09-20-2014, 12:53 PM
  5. Show us your home screens!
    By joebloggs13 in forum LG G3
    Last Post: 09-20-2014, 12:40 PM
