1. Shehryar Zaheer's Avatar
    hello guys, I have an htc desire s. Problem with my phone is that when i unplug the charger charging does not drain even after one hour of usage or heavy usage and then when battery starts to drain after an hour it drains fastly. I have tried a battery change, changed charger but nothing happened. Any help please!.
    09-20-2014 10:57 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! With some devices, you can try to recalibrate the battery meter by letting the battery drain normally until you get the warning (or it shuts off automatically), then charge up on a wall outlet to 100%. I might help if you power the phone off before charging back up. You might also have to do this 2-3 times before things get recalibrated. Hopefully it works for you!
  3. B. Diddy's Avatar
    09-21-2014 12:58 AM
  1. Problems unlocking phone
    By buggyman in forum AT&T
    Last Post: 09-25-2014, 11:41 PM
  2. Can anyone help with smart remote app for Galaxy S5?
    By Rocketsfan521 in forum Samsung Galaxy S5
    Last Post: 09-24-2014, 07:42 PM
  3. Smart Remote Problems
    Last Post: 09-23-2014, 06:04 PM
  4. Replies: 1
    Last Post: 09-23-2014, 05:21 PM
  5. Battery Charge Level Missing
    By Double Tap in forum Google Nexus 4
    Last Post: 09-23-2014, 04:35 PM
