1. AC Question's Avatar
    my Phone fell in dirt now it wont work anymore my blu studio 5.0
    09-21-2014 11:44 AM
  2. belodion's Avatar
    Did it get wet? If so, read this from an AC member:
    http://androidforums.com/faqs/815124...-try-save.html
    If it didn't get wet, try removing and replacing the battery, then see whether it will start.
    09-21-2014 12:08 PM
  3. Rukbat's Avatar
    If it got wet more than an hour ago, it's probably too late. My usual line is that if your phone falls in the water at the same time your pants fall down, take the battery out of the phone before pulling your pants up - that's how little time it takes to ruin the phone if it's wet. (I wrote that article that belodion linked to, btw.)
    If it just got dirty (you didn't specify what you meant by "dirt" - if it fell to the ground on bare earth, where there's no grass, that's also "in the dirt"), it's probably the shock of falling that caused a problem, and you'll have to bring it to a repair shop for an estimate. It could be anything from a loose power switch connection (5 minutes of labor. most of it for opening the phone and putting it back together) to a cracked motherboard (probably close to or more than the price of a new phone).
    09-21-2014 02:10 PM
  1. The ideal phone size
    By arn_hsn xt1022 in forum General News & Discussion
    Last Post: 09-27-2014, 03:40 AM
  2. Mail won't sync on Data
    By ecufan in forum HTC One M7
    Last Post: 09-22-2014, 09:56 PM
  3. Change how wi-fi comes on when plugged into charger?
    Last Post: 09-21-2014, 04:32 PM
  4. Quick camera access on Note 3
    By SMGriffiths99 in forum Ask a Question
    Last Post: 09-21-2014, 02:47 PM
  5. Dropped my samsung s4 need help
    Last Post: 09-21-2014, 02:03 PM
