1. AC Question's Avatar
    I have a Samsung Galaxy S4, running 4.4.2. I have 16 Gigabytes of internal storage, and a 64 Gigabyte MicroSD Card. I only have one gigabyte of available space on the internal memory. This is only because I spent all morning clearing it. When that free space gets down to about 300 MB, I can no longer install apps. Is there a way that I can make everything store on my MicroSD card? It seems like such a waste to have a large card and not be able to use it much. I know that you can move files using My Files, but it never works smoothly; I select all files and Move to SD Card, but it always stops transferring part of the way through. Please help me, I really need it.
    09-21-2014 03:34 PM
  2. joganjani's Avatar
    I've the same setup and have moved everything other than app to sd card. Have you tried moving one by one? What do you have on card now?
    09-21-2014 04:35 PM
  3. KeepItReal's Avatar
    If you are transferring files, and it stops part ways, you need to explore the possibility that it is the SD card or worse case the SD slot in your S4. Take your SD Card out of your S4, put it into a USB reader. Copy all you files to your laptop. Then reformat the card IN your S4. Then take SD Card out, back into USB reader and copy your files from the laptop to the SD card. Put SD back into phone. Try and copy files from internal memory to the card. If it pauses and stops again, try a brand new formatted SD Card. Still happens? Back up your phone (either through carrier supplied apps like Verizon's Cloud or download Samsung Kies to laptop and use that to back up, or some app that meets your needs in the Playstore) then Factory Reset. After Factory Reset, New card, and it still happens? Take it to your carrier for warranty or insurance replacement verification. Good luck!
    09-21-2014 04:48 PM
  1. Can I do group messaging on a LG G3??
    By blackmage303 in forum Ask a Question
    Last Post: 09-16-2015, 10:16 AM
  2. Replies: 6
    Last Post: 10-09-2014, 07:35 PM
  3. Replies: 4
    Last Post: 09-21-2014, 07:37 PM
  4. How to turn off Hands Free Mode in an S4?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 09-21-2014, 05:30 PM
  5. Cannot connect to 3g or 4g after unlocking samsung s3
    By orangesmasher221 in forum Ask a Question
    Last Post: 09-21-2014, 03:31 PM
