1. AC Question's Avatar
    I have unchecked all the boxes recommended. Will I lose all my apps, contacts, etc. with a factory reset? Also is this only happening on the DROID?
    09-22-2014 10:25 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is the phone saying anything else to you? It might be an Accessibility setting, like Talkback. Go to Settings>Accessibility, and see if any of the functions are turned on.
    Instead of doing a factory reset, you could try a cache partition wipe, which won't erase any personal data. Which Droid do you have? The process can vary with the device.
    09-22-2014 10:43 AM
  1. Replies: 3
    Last Post: 09-27-2015, 09:00 PM
  2. Still have verizon unlimited data (US), can I suspend it?
    Last Post: 10-06-2014, 08:16 AM
  3. Replies: 1
    Last Post: 09-23-2014, 03:36 AM
  4. Replies: 5
    Last Post: 09-22-2014, 01:23 PM
  5. Replies: 0
    Last Post: 09-22-2014, 07:09 AM
