1. AC Question's Avatar
    Hey guys, I bought a Spigen Neo Hybrid case for my Galaxy S4 earlier this Summer, and the frame *FINALLY* broke. When I bought the case, I knew I would eventually have to replace the frame, but figured it was worth it to get what I wanted.
    No longer can I buy a Replacement Frame only from Amazon.. any ideas of what happened, or where I am able to buy the replacement frame only?
    Thanks
    09-23-2014 04:03 PM
  2. dpham00's Avatar
    Contact spigen, they might send you one free or sell you a frame onky
    Sent from my LG G Pad 8.3
    09-23-2014 04:28 PM
  1. Samsung Note 2 - Metal Bezel Replacement and Leather Back cover.
    By Benny Stephan in forum Samsung Galaxy Note 2
    Last Post: 10-03-2014, 07:36 PM
  2. note 3 neo
    Last Post: 09-23-2014, 07:51 AM
  3. what do i need replaced?
    By tishap210 in forum Ask a Question
    Last Post: 09-23-2014, 03:21 AM
  4. Samsung Galaxy Note 3 Neo SM-7505 (16GB)
    Last Post: 09-23-2014, 02:30 AM
  5. replaced screen no power
    By clindsay in forum Ask a Question
    Last Post: 09-22-2014, 05:49 PM
