1. Jessica Z's Avatar
    The white antenna cable on my Nexus 5 is broken. When looking for a replacement, i'm mostly only finding the black "coax" cable. Is this interchangeable? Or, for that matter, is the Nexus 4 white cable interchangeable?
    09-23-2014 07:30 PM
  2. Sophia Zhao's Avatar
    Yes it it. This seems is the white one OEM Signal Flex Cable for LG Nexus 5 D820 White - Witrigs.com
    Hope can help you!
    09-23-2014 11:36 PM
  1. Samsung Note 2 - Metal Bezel Replacement and Leather Back cover.
    By Benny Stephan in forum Samsung Galaxy Note 2
    Last Post: 10-03-2014, 07:36 PM
  2. Can you use Facetime on the Nexus 4?
    By WildDragonfly in forum Google Nexus 4
    Last Post: 09-26-2014, 04:56 PM
  3. Nexus 10 with Netgear Push2TV
    By vomogs in forum Google Nexus 10 Tablet
    Last Post: 09-24-2014, 06:58 AM
  4. Spigen Neo Hybrid Replacement Frame?
    Last Post: 09-23-2014, 04:28 PM
  5. nexus 5 in europe
    Last Post: 09-23-2014, 03:17 PM
