1. AC Question's Avatar
    Hey guys,
    My nexus 5 battery is draining crazy!. I left my phone for about 6 hours and it was drained about 12%. I have turn off the vibration, wifi,mobile data, nfc, bluetooth, screen brightness and timeout and using art instead of dalvik. My nexus 5 isn't rooted and i use standard wallpaper. I have this problem since i did factory data reset on my phone. I am using juice defender and wake lock detector. Does anyone know how to fix this problem? Thanks.
    09-24-2014 12:54 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Battery saving apps like Juice Defender can sometimes be counterproductive and end up using more battery, especially if they're killing apps automatically. Those apps may be opening again in the background, only to be killed again. This endless cycle costs battery. I would try uninstalling Juice Defender temporarily and see if there is any difference.
    Also, it would be helpful to see your battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    09-24-2014 01:25 AM
  1. Replies: 2
    Last Post: 09-30-2014, 08:23 PM
  2. Netflix on the G3 is awesome
    By lrrowley in forum LG G3
    Last Post: 09-24-2014, 11:49 AM
  3. Replies: 1
    Last Post: 09-24-2014, 01:49 AM
  4. Galaxy S 5 types on its own
    By Jennifer Schlosser Jones in forum Ask a Question
    Last Post: 09-24-2014, 01:35 AM
  5. Replies: 1
    Last Post: 09-24-2014, 01:33 AM
