1. rockam92's Avatar
    yestaerday the battery usage of android system was 92% then i factory restored it at first it was okay but then a few hours later when i intalled some apps it again consumes about 70% battery..
    Attached Thumbnails ANDROID SYSTEM is draining battery..-screenshot_2014-09-24-15-16-13.png   ANDROID SYSTEM is draining battery..-screenshot_2014-09-24-15-16-18.png   ANDROID SYSTEM is draining battery..-screenshot_2014-09-24-15-16-24.png   ANDROID SYSTEM is draining battery..-screenshot_2014-09-24-15-23-51.png   ANDROID SYSTEM is draining battery..-screenshot_2014-09-24-15-23-57.png
    ANDROID SYSTEM is draining battery..-screenshot_2014-09-24-15-29-39.png   ANDROID SYSTEM is draining battery..-screenshot_2014-09-24-15-29-59.png   ANDROID SYSTEM is draining battery..-screenshot_2014-09-24-15-30-06.png   ANDROID SYSTEM is draining battery..-1.png
    09-24-2014 05:59 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    Does the device sit idle a lot?
    Even though the OS says 76% drain, that is 76% of the 46% drain. So really, only 34% of your total drain is from the OS. Whenever you aren't using your device, the OS is draining it.
    However, have you tried a reboot?
    09-24-2014 09:52 AM
  1. T-Mobile Note 4 bands - spec sheet is up - no 12
    By jpr in forum Samsung Galaxy Note 4
    Last Post: 09-29-2014, 11:23 PM
  2. Replies: 1
    Last Post: 09-24-2014, 02:59 PM
  3. Replies: 0
    Last Post: 09-24-2014, 03:06 AM
  4. how to root android one
    By Shubham Gehlot in forum Ask a Question
    Last Post: 09-24-2014, 01:52 AM
  5. Replies: 0
    Last Post: 09-24-2014, 01:27 AM
