1. drrobg's Avatar
    What is the best app or way too figure out battery drain?
    09-24-2014 03:57 PM
  2. SpookDroid's Avatar
    The general consensus is GSam Battery Monitor. It can be kinda hard to read, though, but it gives you a very accurate picture of who's doing what. Bear in mind that this is NOT battery consumption, is processing cycles and wake locks, so by general rule of thumb, if it's keeping your device awake or if it's doing something in the background it only follows that it's also consuming battery, but in some cases, that's not it (ten seconds of HEAVY processing can consume more battery than 15 minutes of light activity, and yet the latter will show up on top). It's a good guideline, just not always the real answer. You still have to sip through the info to get there.
    09-24-2014 04:12 PM
  3. Rukbat's Avatar
    Also run Wakelock Detector to see what's keeping your phone awake and Greenify to hibernate the apps that do. (Don't hibernate apps like Phnone or your email app, or they won't receive anything unless you're running them.)
    If you look at the battery grapph in Settings, then tap the graph you'll get another page. At the bottom of that graph are a few lines. One of them is Awake. It should be almost completely black, except for times you were using the phone. Greenify will make it more black, making the phone use less battery. (It uses less when it's asleep than when it's awake.)
    09-24-2014 05:29 PM
  1. Sudden Battery drain in moto-x first gen
    By Ritesh jain3 in forum Moto X (2013)
    Last Post: 10-07-2014, 01:39 PM
  2. S3 battery problem
    By hafmb in forum Ask a Question
    Last Post: 09-26-2014, 10:38 PM
  3. Verizon NI2 update - Massive battery drain
    By lehorn in forum Samsung Galaxy S5
    Last Post: 09-26-2014, 07:49 PM
  4. Why isn't the wifi working and I have no battery backup?
    Last Post: 09-24-2014, 10:30 PM
  5. Cost to replace Nexus 5 battery?
    By akuki in forum Google Nexus 5
    Last Post: 09-24-2014, 04:07 PM
