1. AC Question's Avatar
    I plugged my Strat into its normal charger, it makes a popping noise and vibrates every few seconds. I took out the battery but the popping sound still occurs. My phone has never been exposed to water.
    09-25-2014 01:41 PM
  2. Rukbat's Avatar
    It may never have been exposed to water, but something inside still went bad. It could be as simple as a bad connection on the microUSB connector or as bad as a bad motherboard. You'll have to bring it in for an estimate.
    09-25-2014 03:54 PM
  1. Should be getting my Xperia Z3 next week!
    By smooth4lyfe in forum Sony Xperia Z3
    Last Post: 09-26-2014, 01:52 AM
  2. Replies: 1
    Last Post: 09-25-2014, 07:16 PM
  3. Replies: 1
    Last Post: 09-25-2014, 03:56 PM
  4. How do I see my web history from my Galaxy S4 on my laptop
    Last Post: 09-25-2014, 01:28 PM
  5. How do I see everything on the clipboard?
    Last Post: 09-25-2014, 01:24 PM
