1. AC Question's Avatar
    I tried to hold the power button, but that didn't help.
    09-28-2014 03:02 AM
  2. coddman's Avatar
    How long did you hold the power button for? Try holding it for at least seven seconds.
    If that didn't work, try holding Volume up + Power button, going into recovery mode, and reboot the tablet from there.
    If you have an SD card inserted, remove it first.
    Also try holding down the power button on the top and, at the same time, press one finger on the screen firmly until it reboots. [Sources: Google, and other posts on this forum]
    Sorry if none of this helps. Someone else will be along soon to help you, and welcome to Android Central :)
    09-28-2014 03:14 AM
  3. Sadistic_heroine's Avatar
    Thanks! :3
    09-28-2014 03:23 AM
  1. Help: Nexus 5, Samsung Gear2 Neo, and apps
    By lightingbird in forum Nexus 5 Accessories
    Last Post: 09-29-2014, 03:38 AM
  2. Is is possible to restart a dead Galaxy Tab Lite Y?
    Last Post: 09-29-2014, 03:37 AM
  3. Replies: 1
    Last Post: 09-28-2014, 02:09 AM
  4. Why does the Galaxy S5 Lag and Freeze so much?
    Last Post: 09-28-2014, 02:05 AM
