1. AC Question's Avatar
    Hello*!
    I tried a lot of time to root my Tablet (Samsung Galaxy Tab 4 – SM-T535, Android version 4.4.2) with Kingo and others, I did not success. The 'USB Debbuging' is ticked off.
    Could you give with some tips*? Thank you for your help.
    09-28-2014 12:07 PM
  2. Rukbat's Avatar
    Try Towel Root. (I can't post the link - the forum throws a security error - but Google will find it for you). Kingo won't work on 4.4+ versions of Android, and they have no plans to work on a version for it. Towel runs as an app on the phone (no computer needed) and uses an exploit in Linux itself, so it's pretty device-independent.
    09-28-2014 03:03 PM
  1. Why is my internal storage full?
    Last Post: 09-29-2014, 05:35 PM
  2. Replies: 1
    Last Post: 09-29-2014, 02:51 AM
  3. Replies: 1
    Last Post: 09-28-2014, 03:45 PM
  4. Replies: 0
    Last Post: 09-28-2014, 12:05 PM
  5. Should I buy Warrenty for my S5?
    By shuttle099 in forum AT&T
    Last Post: 09-28-2014, 11:04 AM
