1. AC Question's Avatar
    hi there my s3 wont charge from a cig lighter.and my tecknet power pack any more.itwill only charge from the wall .ive replaced the battery, but that hasnt helped.baffled. it suddenly started to play up.is my phone broke
    09-29-2014 05:49 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you using the same USB cable to connect to the car charger or the power pack as you do to the wall charger? Or are they separate cables?
    09-29-2014 12:45 PM
  1. Replies: 1
    Last Post: 09-29-2014, 12:47 PM
  2. Replies: 1
    Last Post: 09-29-2014, 06:00 AM
  3. Replies: 0
    Last Post: 09-29-2014, 05:42 AM
  4. Replies: 0
    Last Post: 09-29-2014, 05:03 AM
  5. How can I get the voice recorder back on my S5?
    Last Post: 09-29-2014, 04:32 AM
