1. AC Question's Avatar
    I have a brand new samsung galaxy s3 and am unable to get a strong constant wifi connection, either at home on my virgin media super hub or when i am out and about, this also happened on my older samsung galaxy s3 please help ?? I am on virgin mobile network
    09-29-2014 01:22 PM
  2. sconrad308's Avatar
    Are you using Knox? I noticed that with Knox installed on mine it kept kicking me off the wi-fi. Also in your Wi-Fi settings make sure that it is set to keep Wi-Fi on during sleep and and also see if Auto network switch is turned on.
    09-29-2014 01:54 PM
  3. Rukbat's Avatar
    Note:
    Auto network switch chould be turned off - sconrad didn't make that too clear. That's the usual cause of the "signal too weak" problem.
    09-29-2014 02:11 PM
  1. How can I change my androidcentral username?
    By lh3 in forum Ask a Question
    Last Post: 03-05-2015, 10:23 PM
  2. Replies: 1
    Last Post: 10-02-2014, 02:34 PM
  3. Replies: 1
    Last Post: 09-29-2014, 02:12 PM
  4. Using my Samsung Calendar ???
    Last Post: 09-29-2014, 02:04 PM
  5. Can you get sfiftkeys on that Samsung Galaxy Tab 2?
    Last Post: 09-29-2014, 02:01 PM
