A
AC Question
Battery draining more than usual.
Using an LG Optimus Pro with v. 4.4.2. This phone has never had battery drain issues. I make sure wifi, Bluetooth, and location are turned off when not in use. Now the phone is down to 90% after an hour off the charger. Is Google Play Store the culprit? I can't disable it. Any thoughts?
