1. AC Question's Avatar
    Using an LG Optimus Pro with v. 4.4.2. This phone has never had battery drain issues. I make sure wifi, Bluetooth, and location are turned off when not in use. Now the phone is down to 90% after an hour off the charger. Is Google Play Store the culprit? I can't disable it. Any thoughts?
    09-30-2014 09:32 AM
  2. Rukbat's Avatar
    How old is the battery? How far do you normally discharge it before charging it? With the way most people handle their phone batteries, 2 years is a good long life. If you constantly discharge it almost all the way you're lucky to get 1 year of use out of it.
    09-30-2014 09:58 AM
  1. Replies: 10
    Last Post: 10-02-2014, 10:54 PM
  2. Stumbled upon a review of a battery need suggestion
    By prevera in forum Samsung Galaxy S5 Accessories
    Last Post: 10-02-2014, 08:30 AM
  3. OTA may bring more LTE bands to the Pure Edition XT1095
    By Phil Nickinson in forum Moto X (2014)
    Last Post: 09-30-2014, 07:07 PM
  4. Replies: 4
    Last Post: 09-30-2014, 03:01 PM
  5. Replies: 1
    Last Post: 09-30-2014, 02:07 AM
