1. AC Question's Avatar
    I noticed a couple of days ago that the battery level indicated on my note 2 was surprisingly low. I restricted background activity on all the apps that I could, and switched to my fully charged backup battery. In the morning, the barely used battery looked like it was almost drained. Not believing it, I restarted the phone and it indicated 90%. This continues with both batteries. I'm conviced that it's the phone. Is there anything I can do to fix it?.
    10-01-2014 11:15 AM
  2. belodion's Avatar
    Try a Cache Partition wipe, or even a Factory or Master Reset if your personal data is backed up:
    http://support.t-mobile.com/docs/DOC-6768
    It may also be worth calibrating the battery.
    10-01-2014 02:01 PM
  1. Where is the clipboard on a Droid RAZR MAXX?
    Last Post: 10-01-2014, 05:59 PM
  2. Why is my micro SD card not recognized by my mobile?
    Last Post: 10-01-2014, 05:57 PM
  3. why the micro memory card is not recognizing by my mobile
  4. Screen Protector and Note 4 Case
    By lazerproof in forum Samsung Galaxy Note 4
    Last Post: 10-01-2014, 10:45 AM
  5. Replies: 0
    Last Post: 10-01-2014, 09:33 AM
