1. AC Question's Avatar
    My phone is a Android 4.4.2. When i buy the phone first then i installed so many apps. Though it was fine!
    After 1 month it started showing low internal storage on Settings>Apps>Downloaded.
    (915MB used, 85MB free)
    Then i was annoyed and factory reset the phone. After that i again installed some few apps and it was runnig good. But again some days later. It started showing low internal storage.
    So i uninstalled all apps (Except the apps those were given with the phone & the updates of those apps)
    But still it is showing low internal storage.
    N:B: Im using "Vault" software. And there are a few items there, not so large file.
    Please help me what can i do???
    10-01-2014 11:50 AM
  2. lutfor's Avatar
    I moved the Apps to SD card also. Please help me.
    10-01-2014 11:54 AM
  1. Kairos Smartwatch wil not support Android Wear
    By aitt in forum Android Wear
    Last Post: 10-05-2014, 10:53 PM
  2. Replies: 1
    Last Post: 10-01-2014, 05:56 PM
  3. How do I power off my HTC One phone?
    Last Post: 10-01-2014, 02:14 PM
  4. How do I send a group text message from my Razor M?
    Last Post: 10-01-2014, 09:41 AM
  5. Replies: 1
    Last Post: 10-01-2014, 08:54 AM
