1. AC Question's Avatar
    So, it happened yesterday, I installed android 4.2.2 on my Samsung Galaxy Tab 2 7.0 GT-P3100 week ago, and yesterday my tablet turned off on 94% battery, then i put it on charger. After i turned it on, battery screen like when u put it on charge was still on screen even if it was not charging. then i tried to turn it on, and i couldnt. so i pressed powe and vl. up button and reseted it. After that i had 4% of battery, and i put it on charging, but it turned off, and again showed charging battery screen. Plese help me ASAP!
    10-02-2014 10:54 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Recovery and wiping the cache partition, which won't erase any personal data: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    10-02-2014 06:15 PM
  3. android9991's Avatar
    Hi, i asked question about battery problem, so i deleted chache memory in recovery mode, and now i do not have problem with baterry display, now i have battery problem. So my device turned off while playing Boom Beach, then i turned it on normally and i had 1% battery. Then i put it on charger and it charged to 28%, and after about 15 s it showed 100% charged. I disconnected it and same problem happened again. Please help.
    10-03-2014 09:13 AM
  4. B. Diddy's Avatar
    Are you the original poster on this thread?
    You may have to recalibrate the battery meter. Use the tablet until it shuts off on its own. Then charge it on a wall outlet without disturbing it for 6-8 hours. Power on again, and use it normally again until it shuts off on its own. Repeat 2-3 times. Then see if it works more normally.
    10-03-2014 10:21 AM
  5. android9991's Avatar
    Yes, yes I am, ant thank you.
    10-03-2014 11:23 AM
  1. Where has the Play Store gone to on my LG G3?
    Last Post: 10-02-2014, 06:54 PM
  2. Why is my battry draining so fast?
    Last Post: 10-02-2014, 06:19 PM
  3. Replies: 1
    Last Post: 10-02-2014, 06:17 PM
  4. My S3 Mini keeps restarting all the time . what should I do?
    Last Post: 10-02-2014, 11:27 AM
  5. Replies: 0
    Last Post: 10-02-2014, 10:31 AM
