1. AC Question's Avatar
    I can't use my camera due to it keeps saying mount storage before using the camera.
    10-02-2014 02:31 PM
  2. Jim_in_VA's Avatar
    means if you are using a SD card to store photos you have to mount it through the settings menu first
    10-02-2014 02:35 PM
  3. Thomas Sanders1's Avatar
    I am getting the same message, but my SD card is already mounted. I can see my pictures in the gallery and my music showsin the player. But iI still get the message when trying to use camera. It won't take a picture do to this error. Any advise?
    11-04-2014 10:09 AM
  4. Teresa August's Avatar
    Well don't unmount the card because it will erase everything! I had the same thing with last persons reply..it etaded all picz and videos on card.
    11-14-2014 06:59 PM
  5. Teresa August's Avatar
    I recommend a good backup so you can retrieve your info.
    11-14-2014 07:07 PM
  6. Teresa August's Avatar
    I had the same problem. What I did was use CM back up saved my info. Called zte they said to go to settings select apps scroll top of screen it will say SD card then run then all. Select all. Then scroll down to camera and select data ...press clear data. I restarted my phone.took a few hours but got all my info back. I hope this helps.
    11-14-2014 11:21 PM
  7. bettyadams's Avatar
    01-26-2016 09:06 PM
  1. Replies: 1
    Last Post: 12-09-2014, 11:30 AM
  2. Corrosion on the Moto 360?
    By C. Scyphers in forum Moto 360
    Last Post: 10-23-2014, 04:42 PM
  3. Samsung Performs The Gluteus Maximus Test On the Galaxy Note 4!
    By Preach2k in forum Samsung Galaxy Note 4
    Last Post: 10-02-2014, 03:37 PM
  4. Does Google Wallet use Tokenization?
    Last Post: 10-02-2014, 01:54 PM
  5. Deleting pics within the Photos app & Auto-Capitalization
    By Todoroff in forum Sony Xperia Z3
    Last Post: 10-02-2014, 01:15 PM
