1. AC Question's Avatar
    Hello All!
    I have looked through all sorts of forums but cannot seem to find info that is a) recent or b) correct.
    My wife and I just did the BYOP from AT&T to Straight Talk. I have a Galaxy S3 and she has a iPhone 5. Both are/were locked, but the Straight Talk person told us that it didn't matter as long as we used compatible SIM cards.
    I can get almost everything working on my phone EXCEPT MMS. Any help?
    Her phone? Well, it's a disaster. Calling works, but that is all. Can't browse the internet, can't do anything (unless it's on WIFI, of course). I can't even figure out how to adjust the APN settings on an iPhone.
    Please help!
    10-02-2014 06:51 PM
  2. 32gig's Avatar
    For MMS to work, make sure that mobile data is enabled, MMS requires a data connection to work, won't work on just WiFi.. And on the iPhone no clue.. I've heard stories of byop for iphones is complicated..
    11-07-2014 08:20 PM
  3. butterhasbeenspread's Avatar
    For Android, you have to find the correct APN (Access Point Name) settings for your phone. The iPhone doesn't let you manually adjust the APN, it is done through a website you access through your iPhone via WiFi connection.
    12-17-2014 03:46 PM
  1. Just held a Note 4 at Best Buy.
    By nyc_rock in forum Samsung Galaxy Note 4
    Last Post: 10-06-2014, 01:02 AM
  2. Replies: 4
    Last Post: 10-04-2014, 07:34 AM
  3. How do I get my Bluetooth on my S5 to connect?
    Last Post: 10-02-2014, 06:47 PM
  4. How can i recover deleted text from my Note 3?
    By Renegadepits in forum General Help and How To
    Last Post: 10-02-2014, 06:42 PM
  5. Replies: 1
    Last Post: 10-02-2014, 06:35 PM
