Yes, why is my battery draining so fast?
ittiandro
Active member
Nov 28, 2013
27
I have a Samsung Galaxy 4 tablet, which I use mostly for reading books.My reading habits have not changed, but I noticed that my battery drains much faster than before since I started using floating windows ( multi windows). Actually today I couldn't even reboot the tablet and when I put it on charge the level was at the lowest I've ever seen. Practically empty. Is it possible that the floating windows drain the battery more?
Thanks
Ittiandro
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,595
4,737
113
It certainly could be contributing. To get a better idea of what's using your battery, charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/am...ide-how-post-screenshots-android-central.html
RemusGhostofRome
