1. AC Question's Avatar
    Hello,
    I have a Samsung Galaxy Note 3, and I encrypted both the phone and SD card.
    Typing password any time screen locks is more than annoying, it became a nightmare! As there is no way to disable auto screen lock and type the password only when I start the device, I decided to unencrypt it, but I know it is not possible.
    So I did the complete backup (all seemed fine except some apps Kies reported are not backed up, not giving any details).
    The question is: can I just factory reset the device, then restore the backup on the unencrypted device? Will the SD card work unencrypted recovering all data from Kies?
    Thank you very much
    A
    10-03-2014 11:32 AM
  2. Rukbat's Avatar
    If you backed up an encrypted file, reset the phone, then restore the backed up file, it will still be encrypted - but you'll never be able to decrypt it any more.
    10-03-2014 10:17 PM
  3. nombiker's Avatar
    While encrypting i turn off my phone.and my all data is lost.so how can i restore my data.please answer
    10-26-2016 05:33 PM
  1. Replies: 15
    Last Post: 03-12-2017, 10:23 AM
  2. Replies: 60
    Last Post: 10-16-2014, 02:55 PM
  3. Replies: 1
    Last Post: 10-03-2014, 11:42 AM
  4. How do I attatch a picture to a text or email?
    By chelmer640 in forum Ask a Question
    Last Post: 10-03-2014, 11:32 AM
  5. Replies: 0
    Last Post: 10-03-2014, 11:29 AM
