1. AC Question's Avatar
    This didn't use to happen before, but I don't know how it happened. While I'm on a call, on any calling apps (Skybe, LINE, Kakao) whenever the tablet makes a sound, the sound of the call cuts off (not completely, just for the second or so that there's a sound). So you know how every time you tap the screen it makes a sound? well the call sound cuts off every time. Is there any way to fix this? I don't know what happened, but it's annoying.
    10-03-2014 11:38 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Have you considered turning off the screen touch sounds? Go to Settings>Device-Sound, and uncheck Touch Sounds.
    10-03-2014 06:37 PM
  1. About red circle with a white "X" on the screen
    By marica66 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-22-2014, 08:44 PM
  2. Facebook beeps with notifications off...
    By Stwutter in forum LG G3
    Last Post: 11-07-2014, 08:27 AM
  3. Web filtering for Galaxy Tab S
    By peacefulberry in forum Ask a Question
    Last Post: 10-03-2014, 02:07 PM
  4. Replies: 1
    Last Post: 10-03-2014, 11:42 AM
  5. Replies: 1
    Last Post: 10-03-2014, 10:53 AM
