1. AC Question's Avatar
    My battery drains instead of charging why?
    10-05-2014 12:23 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! What phone do you have? Are you plugged into a wall outlet or a computer USB port? USB ports charge much more slowly, and if you're actively using the phone, the charging current might not be enough to keep up with the drain.
    When you plug the phone in, do you see the lightning bolt appear in the battery icon? If not, the charging port itself might be broken.
    10-05-2014 12:38 AM
  1. Replies: 4
    Last Post: 06-19-2015, 06:59 AM
  2. Battery life cycle
    By ray1945 in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-05-2014, 01:45 PM
  3. Replies: 3
    Last Post: 10-05-2014, 10:26 AM
  4. Replies: 1
    Last Post: 10-05-2014, 12:56 AM
  5. Replies: 0
    Last Post: 10-04-2014, 09:45 PM
