1. AC Question's Avatar
    cant do anything, have to keep it in charge all day so it doesnt die
    10-05-2014 07:23 PM
  2. cajunaggie87's Avatar
    20 minutes? Really? Wow that's pretty bad. Well first thing you can do is check to see what has been eating up your battery. You can check your battery usage and it will tell you the culprit. I'm not sure if there is any app that can eat through 100% of your battery that fast though. There may be an issue with your phone or battery. Check the usage stats first and if it is a newly installed app, uninstall it and see if that helps.
    10-05-2014 09:22 PM
  1. Mint Verizon Lg G3 in White
    By StayFly in forum Marketplace Archive
    Last Post: 10-13-2014, 09:27 PM
  2. Any good Stock/AOSP rome for the Verizon HTC One M8?
    By Eli_Finn in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 10-06-2014, 12:11 PM
  3. Can I Auto tether my phone?
    Last Post: 10-05-2014, 07:18 PM
  4. Replies: 1
    Last Post: 10-05-2014, 07:11 PM
  5. Replies: 1
    Last Post: 10-05-2014, 07:09 PM
