1. AC Question's Avatar
    I went from a Motorola Droid to a Samsung s5, my volume issue started with the first and continues on my current s5. I used to pair my phone to a speaker on my bike and it was great. What I remember is an update occurred and the volume on my speaker is more than cut in half, on two different (but same model) speakers it's the same issue. When the 3.5 cable is used volume is what it was before the update. In my trouble shooting ive tried apps to no avail adjusting the volume, trying to adjust on the settings menu, and while paired taking the volume all the way down and back to max. The results are all the same and the speaker volume is just not half as loud at max paired over blutooth compared to physically plugged it. Outside of rooting is there any fix for this??? Thanks.
    10-05-2014 08:55 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! What happens if you unpair the speaker, and then pair it again?
    The other thing I would try is to boot into Recovery and wipe the cache partition: Reset: Samsung Galaxy S 5 | T-Mobile Support
    10-05-2014 09:15 PM
  3. Edward Boylan's Avatar
    Hey I submitted the original question above. Unpairing and pairing again has no affect.
    10-05-2014 09:37 PM
  1. Note 4 Android Authority Review
    By Linebarrel86 in forum Samsung Galaxy Note 4
    Last Post: 02-27-2015, 02:17 PM
  2. Replies: 1
    Last Post: 12-15-2014, 03:37 AM
  3. Why do my headphones not work on my android phone but they do on my iPod?
    By its-strawberry-jello in forum Ask a Question
    Last Post: 10-18-2014, 10:01 AM
  4. What is the best app to update my android phone?
    Last Post: 10-05-2014, 09:31 PM
