1. AC Question's Avatar
    I have this Huawei S7-951wd (Telpad), the USB charger works, USB pc connection works, but the problem is when i put USB drive in the micro USB slot for on the go my USB drive is not detected and even no led light flashing from the USB. But when I try it to my cousin's Huawei S7-951wd (same brand and model) it works, no problem at all.
    So I came up with solution that maybe my USB Drive is not powering that's why it is not detected, so I made a wire connection for the power (Red and Black) to the USB SLOT in the PC and the data from my USB to the tablet, it powered up but still not detected.
    Please anyone that can help me? thanks in advance
    10-06-2014 09:56 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you confirm that you're using an OTG adapter/cable, or is it just a microUSB-to-USB cable?
    10-06-2014 10:44 AM
  3. toyapogi's Avatar
    yes im using OTG cable, ive also tried otg usb drive but still not detected
    10-06-2014 10:57 AM
  4. toyapogi's Avatar
    up...
    10-07-2014 04:00 AM
  1. Leaving the S5 for the Note 4
    By BigCrimsonTX in forum Samsung Galaxy S5
    Last Post: 10-07-2014, 10:56 PM
  2. Replies: 1
    Last Post: 10-06-2014, 03:08 PM
  3. Replies: 1
    Last Post: 10-06-2014, 10:50 AM
  4. Galaxy Tab S 10.5 not reading GoPro Camera via USB OTG??
    By pdee4t in forum Samsung Galaxy Tab S 10.5
    Last Post: 10-06-2014, 09:38 AM
  5. Replies: 1
    Last Post: 10-06-2014, 09:28 AM
