1. AC Question's Avatar
    my phone wont read my sd card, the screen freezes, i took to my provider and they keep saying its the software that i need to replace the keyboard... i can't accessmy playlist.. whats wrong with my fone?? I have an CDMA HTC incredible Android
    10-06-2014 07:39 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Recovery Mode and wiping the cache partition, which won't erase any personal data: Droid Incredible Wipe Cache Partition | To Hell in a Handbasket
    Also, have you tried using the phone without that SD card inserted? If the card is corrupt, it could be causing other problems. Try using no card, or a different one.
    10-07-2014 01:20 AM
  3. sonyacruz77's Avatar
    OK i did the droid incredible wipe cache partition, and it went well. for some reason now i cant take pictures or save them to my gallery. what happens now?
    10-12-2014 11:34 PM
  1. How do you reset an LG Optimus straight talk phone?
    Last Post: 01-27-2016, 06:01 PM
  2. Replies: 1
    Last Post: 10-07-2014, 08:58 AM
  3. How do I stop unwanted running apps
    Last Post: 10-07-2014, 01:26 AM
  4. How to do a full backup of my DroidX?
    Last Post: 10-06-2014, 07:09 PM
  5. Failure to send email
    Last Post: 10-06-2014, 07:07 PM
