1. AC Question's Avatar
    My S5 making a tink tink sound when finding location. It happens when the icon is flashing in the notification bar, like when I first boot the phone or when it looses a wi-fi signal, or randomly in the middle of the night, waking me up. If I turn off location it doesn't make the sound. I have the mode set on High Accuracy. It's very annoying because whenever the phone loses the location it makes the noise, even loudly in my ear when I'm talking on the phone. My S4 didn't do this. My wife's S5 doesn't do it. I can't find any setting to turn it off. How do I make it stop?
    10-06-2014 10:00 PM
  2. Golfdriver97's Avatar
    Welcome to the forums. This might be considered a dumb question: Are you and your wife on the same carrier?
    10-06-2014 11:00 PM
  3. kenkay's Avatar
    I have the same issue... Any help here appreciated. AC, did you resolve the issue.?
    10-29-2014 02:04 AM
  4. kenkay's Avatar
    I resolved the problem. It was a widget I installed called Transparent Weather Clock that had a setting for sounding upon location changes. Voila, the annoying sound is gone.
    10-29-2014 04:42 PM
  1. How do I fix the Google Play Store error [DF-SA-01]?
    Last Post: 11-05-2014, 10:32 PM
  2. Replies: 3
    Last Post: 10-10-2014, 12:07 AM
  3. Where to Buy a Samsung Galaxy s5 motherboard
    By Tigermaw in forum Samsung Galaxy S5
    Last Post: 10-07-2014, 05:23 PM
  4. Replies: 1
    Last Post: 10-06-2014, 10:15 PM
