1. AC Question's Avatar
    When you take a picture on a Galaxy S4, it is given a date and file number automatically
    E.G. 20141007_ 210428.
    Can you reset the camera, so that the next picture you take will be number 1.?
    Thanks
    10-07-2014 03:08 PM
  2. SpookDroid's Avatar
    Unfortuantely, no it can't. You can fake it though. The number it assigns is the date and time the picture was taken, so the only way to fake it is to set your device's date to whatever you want it to show as the file name. HOWEVER, this usually brings bigger problems with other apps.
    There are 3rd party camera apps available that can use different naming conventions. The stock camera can also use Contextual File names based on your location instead of the date/time format.
    10-07-2014 03:15 PM
  1. I have no idea how to fix my device
    By moofiee in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 01-23-2015, 09:31 AM
  2. "No sim inserted" error on HTC M8
    By acE Shanny in forum HTC One M8
    Last Post: 10-09-2014, 03:01 AM
  3. [HELP] My camera has a problem
    By hugorageX91 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-08-2014, 08:50 PM
  4. Replies: 1
    Last Post: 10-07-2014, 10:31 AM
