Stuck on system recovery 3e power button wont select option
Hi, I'm not quite sure how this happened, but my random no name Chinese tablet (no idea of make, as it was a gift) is stuck on the system recovery 3e screen. I can navigate through the options with the volume key, but when I try to select with the power key nothing happens. There are no other keys on it. Please help me, I'm a huge newb when it comes to Tec. Oh and behind the options of the system recovery screen, there is a dead android dude with No Command written underneath:-\
Thanks for the help, but it seems to have sorted itself out. I let the battery run down untill it shut down, then I charged it and it booted up normally. Thanks again for the suggestion, if it ever happens again I'll try that. .
