1. AC Question's Avatar
    I have a Note 2 and some of my friends have told me that the Beats Mixr does not work on the Samsung Galaxy Note 2 along with most Samsung devices. I do not want to open the Beats Mixr as the store I bought it from has a no return policy.
    10-08-2014 12:22 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! If your friends had direct experience with using the Mixr with their Samsung device, then I'd believe them. Headphones that are designed specifically for iOS devices may have limited compatibility with non-iOS devices, due to different headphone configurations. See the support page for more info: Product Compatibility | Beats by Dr. Dre
    10-08-2014 12:33 PM
  3. Rukbat's Avatar
    According to the Beats site, it will work wired (as far as the headphones) with the Note 2. I've reported this error on their page. No idea whether they're a company that cares or not, though.
    10-08-2014 03:59 PM
  4. B. Diddy's Avatar
    Right--the headphones part will work, but it says on the site that the mic and remote controls might not work. Do you know if those features work, Rukbat?
    10-08-2014 05:33 PM
  5. thelastred's Avatar
    Yes if you buy this cable http://forums.androidcentral.com/e?l...token=wkyRSJXt
    12-08-2014 11:48 PM
  1. S4 not playing vines or gifs on Twitter app
    By SeanMurph in forum Samsung Galaxy S4
    Last Post: 12-28-2014, 01:58 AM
  2. Unlock Samsung galaxy s4.
    By vishesh ved in forum Samsung Galaxy S4
    Last Post: 10-09-2014, 10:14 AM
  3. Replies: 1
    Last Post: 10-08-2014, 12:46 PM
  4. Where is the voicemail on my Samsung 4?
    Last Post: 10-08-2014, 12:34 PM
