1. AC Question's Avatar
    Recently, my Samsung GS4 broke so I am now using someone's Note 2. The GS4 works well for MMS and the Note 2's previous owner said that MMS worked as well. Is the MMS not working for me because I am using a different SIM card? I have tried putting in various VPN settings and have downloaded Hangouts and Textra but the MMS still doesn't seem to work.
    10-08-2014 02:48 PM
  2. wizzrah's Avatar
    Welcome to Android Central! What is your service provider?
    Sent from my nifty 2 year old AT&T HTC One XL
    10-08-2014 03:02 PM
  3. Rukbat's Avatar
    The mms server used by your network provider has to be in your APN. Make sure the mmsc is correct for your provider. You shouldn't have a VPN set up at all, but the APN has tio be set up correctly. (They're totally different things.)
    10-08-2014 03:29 PM
  1. Can you delete all text messages at once on 4gLTE?
    By Black5024 in forum Ask a Question
    Last Post: 10-08-2014, 04:12 PM
  2. Status icons and S Note Overlap Problem. Please Help.
    By CurtJ in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-08-2014, 03:41 PM
  3. Replies: 1
    Last Post: 10-08-2014, 02:38 PM
  4. How do I use text to speech in Polaris on my Galaxy Tab 4?
    Last Post: 10-08-2014, 01:47 PM
