1. AC Question's Avatar
    The phone dropped while it was charging. The screen has a dotted type pattern on it now. It goes ;home key& the return key illuminates bu nothing happens when I press it.
    10-09-2014 07:09 AM
  2. belodion's Avatar
    It may be a loose connection, it may be a damaged screen and/or other internal damage. It will need to be diagnosed by a qualified repairer.
    10-09-2014 07:39 AM
  3. Rukbat's Avatar
    If nothing happens when you press the Home key, it's more than a loose connection. As Belodion said, you'll have to take it in for repair (get an estimate first, so you don't have a heart attack when you come back to get it after it's been fixed).
    belodion likes this.
    10-09-2014 11:11 AM
  1. A week with my white Note 4
    By kevin_fan in forum Samsung Galaxy Note 4
    Last Post: 10-13-2014, 04:48 PM
  2. Replies: 2
    Last Post: 10-09-2014, 11:37 AM
  3. Hello, can anyone help me figure out my Moto G2?
    Last Post: 10-09-2014, 11:15 AM
  4. How do I get the free promo code for Google play?
    By Johnnymack29 in forum Ask a Question
    Last Post: 10-09-2014, 10:41 AM
  5. Replies: 0
    Last Post: 10-09-2014, 06:06 AM
