1. AC Question's Avatar
    Plz tell me. My original chargr is not working well. It damaged. So can I use usb cable as alternative chargr by attaching plug at the end of cable same like the I phone charger
    10-10-2014 01:01 AM
  2. Yoplaboom's Avatar
    Hi,
    Sure you can use USB cable to charge your phone. If you plug it to you computer it will charge slower than a real charger, but if you plug it to your charger, it will charge normally.
    10-10-2014 03:56 AM
  1. Replies: 2
    Last Post: 11-14-2015, 10:13 AM
  2. Any bets on the Turbo's price?
    By XDCX in forum Motorola Droid Turbo
    Last Post: 10-24-2014, 06:37 PM
  3. Replies: 1
    Last Post: 10-10-2014, 03:58 AM
  4. Is the new S4.3 supported by Kies3?
    Last Post: 10-10-2014, 12:46 AM
  5. Replies: 0
    Last Post: 10-10-2014, 12:01 AM
