1. AC Question's Avatar
    So I have Galaxy S4, I have been using it little more than a year.
    I charge Galaxy S4 and it will show it is at 100% and then after I unplug from the charger and use it for little while, the battery level will drop drastically to somewhere around 60% range. After that, battery life seems normal around that range.
    Is this problem with the device? or do I need to buy new battery? Please help! Thanks a lot
    10-10-2014 08:27 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. I would try a new battery, see if it helps. You can look here: ShopAndroid - #1 Store for Android Accessories
    10-10-2014 09:16 AM
  3. HFL's Avatar
    Golfdriver97 maybe stop sending him to pages. and help?!
    well im gonna help him!
    mate the main things u need to check
    1.ure battery date [how much time you got it]
    2.check if ure useing a wall adopted electric spliter (to 2 , 11 suckets) > cuz some can make phone get superhot fast
    3.check ure wall adopter of samsung if he does the issues ,
    *check the wall adopter
    *check the usb cable
    * the main reason i say it happend to me before it can make it happend*
    10-10-2014 10:52 AM
  4. Golfdriver97's Avatar
    The rapid drop actually explains the fact that the battery is shot.
    Sent from an AOSP M8
    10-10-2014 03:41 PM
  5. Paul627g's Avatar
    HFL, we appreciate the help in the forums, however please don't call out or make comments concerning the volunteers at Android Central.
    If you have an issue or comment concerning them you can contact me via PM.
    Thank you.
    Sent from my HTCONE using Tapatalk
    10-10-2014 03:47 PM
  1. Look like the Note 4 will have pretty good battery life after all!
    By David Lees1 in forum Samsung Galaxy Note 4
    Last Post: 10-12-2014, 09:00 AM
  2. No Sim Card Detected - AT&T Galaxy S3
    By Justin Emerich in forum General Help and How To
    Last Post: 10-11-2014, 10:39 PM
  3. Why is the display of my Samsung Galaxy Tab flickering?
    Last Post: 10-10-2014, 09:18 AM
  4. Is it possible to track down my stolen phone?
    By JoshChloe Rosewolf in forum AT&T Galaxy S III
    Last Post: 10-10-2014, 08:47 AM
  5. How do I recover my gmail password?
    Last Post: 10-10-2014, 08:10 AM
