1. AC Question's Avatar
    Hello ! So two weeks ago i bought a new S5 . But in the end of the 1st week i forgot my charger in a place.. And i had to use a charger that i had in home (AC ADAPTER Input AC 100-240 V 50/60 Hz Output 5V DC 100mA). 1 week everything was OK but last night i left it charging about 12 pm and took it off at about 11 am and there wasn't that green dot that shows the phone is ready. It was realy heated and didn't boot up. It still doesn't.. nothing happens . I tried removing the battery for 10 mins .. nothing happens again. Please help !!!
    10-11-2014 06:28 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The battery might have failed. Can you try a new battery?
    Try placing your current battery flat on a table and try to spin it. If it spins freely, it's bulging in the middle, which confirms a failing battery. But if it doesn't spin, that still doesn't rule out a battery issue.
    10-12-2014 01:38 AM
  1. Why does my Samsung Note 3 have a weak reception?
    By bigdaddy805 in forum Android 4.4 KitKat
    Last Post: 10-12-2014, 01:53 AM
  2. Replies: 1
    Last Post: 10-12-2014, 01:52 AM
  3. Why won't my tablet charge on its own charger and not sync properly?
    By Jann Benjamin Jaya in forum Samsung Galaxy Note 8.0
    Last Post: 10-12-2014, 01:39 AM
  4. Replies: 0
    Last Post: 10-11-2014, 03:29 AM
