1. AC Question's Avatar
    I upgaraded lenovo s920 to android kitkat . before that my wifi speed wass abt 50 kbps .now after upgrade when i connect it connect and shows full signal bt the speed bar shows near about 0.50 kbps .and sometime it connects and give the same good speed abot what i was getting before uppdate. but most of the time it gives very low speed that .plz help
    10-11-2014 07:48 AM
  2. belodion's Avatar
    First, try wiping the Cache Partition in Recovery Mode.
    Also try Settings, Storage, Cached Data, and wipe the cache.
    B. Diddy's wifi guide may also be helpful:
    http://forums.androidcentral.com/amb...-problems.html
    Golfdriver97 likes this.
    10-11-2014 07:59 AM
  3. Niraj Wagh's Avatar
    i did a factry reset but nothing worked.same speed.Is there any setting by default in Kitkat 4.4.2 which reduces the wifi speed to save power or for any other reason.?
    10-11-2014 12:23 PM
  4. Rukbat's Avatar
    What make router are you using? I had to set up a guest account on a Linksys to get back high speed on my phones after going from 4.3 to 4.4.2 - the laptops still work fine on the regular account. (Don't ask me why, I just designed stuff like that for years, so I'm not going to spend weeks reverse-engineering the router to find out what Linksys did, and they don't seem interested in the seeming anomaly.)
    10-11-2014 04:42 PM
  5. Niraj Wagh's Avatar
    my router is pronet but i am using a leoxsys wireless usb adapter for wifi as my router is not wireless.
    10-11-2014 10:25 PM
  1. Replies: 3
    Last Post: 07-18-2015, 04:53 AM
  2. Replies: 3
    Last Post: 10-14-2014, 02:29 AM
  3. why android is locked my phone?
    Last Post: 10-11-2014, 06:28 AM
  4. How to open and use Text/Excel files in Android?
    By acsurfer in forum General Help and How To
    Last Post: 10-11-2014, 06:19 AM
  5. Replies: 0
    Last Post: 10-11-2014, 05:39 AM
