1. AC Question's Avatar
    Last night I went to sleep with my phone on 100% I woke up and it was on 24%. I liked at my battery usage and it said that 30% was being used by Android System and 25% was being used by com.android.systemui and 9% was being used by Android OS. Also my phone was really hot in the morning and it's hot now I am charging it.
    10-11-2014 08:00 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    Also, consider unmounting the SD card (in Settings>Storage) and removing it, in case a file on the card is corrupt--this can lead to battery drain due to the Media Scanner hanging up on that file.
    10-12-2014 01:26 AM
  3. unklray's Avatar
    Install CM security. There is a cleaner to clean trash, boost memory (clean) and most important 1 tap hibernate which will hibernate
    apps running that drain your battery.
    11-03-2015 02:08 PM
  1. Tab S 8.4 LTE battery drains extremely fast and erratically
    By CaptainCrapnuts in forum Samsung Galaxy Tab S 8.4
    Last Post: 03-15-2017, 07:46 PM
  2. Replies: 1
    Last Post: 10-12-2014, 01:28 AM
  3. Why is my wifi speed very low in Android KitKat 4.4.2.?
    Last Post: 10-11-2014, 10:25 PM
  4. Why isn't my Galaxy S5 contacts list displaying Google or WhatsApp?
    By flexenburger in forum Samsung Galaxy S5
    Last Post: 10-11-2014, 10:32 AM
