1. AC Question's Avatar
    My unit is zenfon 5 purchase last october 5, 2014
    10-11-2014 11:59 AM
  2. belodion's Avatar
    It may need a new battery....batteries can be faulty new, out of the box.
    10-11-2014 12:00 PM
  3. Rukbat's Avatar
    Check the battery stats (Settings/General/Battery) and see what's draining it. The screen should be the heaviest user, and Google stuff shouldn't be far behind. If there's an app right up there with the screen (or even using more battery than the screen), that app is bad.
    If there's no app causing it, and you bought it this year (or was 2014 a typo?), bring it back and ask for a new one. If it's a year old, using it until the battery is down to almost nothing all the time could give you a 12 month life for the battery. (The longest life is when you recharge at the 40% to 60% point.)
    10-11-2014 04:48 PM
  4. Golfdriver97's Avatar
    Had to Google the device. You have a Li-Po or lithium polymer battery, the same that is in the M8. My M8 I had to give it a week (meaning 7 days) of charging before I saw improvement. Since you only have yours for about 6, see what happens in the next couple days.
    Sent from an AOSP M8
    msndrstood likes this.
    10-11-2014 07:13 PM
  1. Transfering Pictures to PC without USB cable?
    By PainFX in forum Samsung Galaxy S5
    Last Post: 10-21-2014, 04:16 PM
  2. Everything you would ever need to know about the note 4
    By honey_bee_33 in forum Samsung Galaxy Note 4
    Last Post: 10-19-2014, 07:39 PM
  3. Why is my Samsung Galaxy S4 not charging?
    Last Post: 10-16-2014, 11:07 AM
  4. Replies: 2
    Last Post: 10-13-2014, 05:09 AM
  5. why does the battery go from 100% to 85 in 10 mins
    Last Post: 10-11-2014, 08:46 PM
