1. AC Question's Avatar
    Well, my device XOLO A500S didn't have any issue regarding the subject of matter that my pc is not able to detect my Device with USB Cable but charges at the same time but i has rose up from now. I can't transfer files but my phone only charges when I connect it to the PC. Can anyone here on this forum help me on this ISSUE!!
    10-13-2014 05:50 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It's possible for cables and/or phone microUSB ports to fail, such that they only charge but don't transmit data. First, when you connect, swipe down your phone's notification shade and see if there's a USB connection notification. If so, tap it and make sure MTP is selected. If there is no USB connection notification, then try a different cable. If that doesn't help, then try connecting to a different computer. If none of that works, then the problem might lie with the phone's microUSB port, in which case you'd have to bring it to a repair shop.
    10-14-2014 02:23 AM
  3. soubhagya's Avatar
    Why Is my device XOLO A500S not detected by USB cable on PC but still charging through PC?
    And the usb dubbing is not functioning till yet.
    01-28-2015 11:11 AM
  1. Nexus 5 - lost my phone on night out - is my data safe?
    Last Post: 10-14-2014, 02:26 AM
  2. My Samsung Galaxy Tab 3 won't turn on how can I fix this?
    Last Post: 10-14-2014, 02:24 AM
  3. Replies: 1
    Last Post: 10-14-2014, 02:23 AM
  4. Replies: 1
    Last Post: 10-13-2014, 08:08 AM
  5. Replies: 0
    Last Post: 10-13-2014, 05:39 AM
