1. AC Question's Avatar
    My lg vs450pp is rooted and I need to restore it to the factory stock system. Like wipe EVERYTHING and start brand new. I have tried EVERYTHING except the Terminal Emulator, which I have BUT using:
    $su
    #flash_image recovery [full path to the recovery image you want]
    I need to know exactly what code to put here ^
    Does this actually help?!? I'm frustrated with trying to do restore this phone but it has to be done.
    *Keep in mind this phone will not connect with a computer via USB.
    10-13-2014 09:33 PM
  2. Shane Calm's Avatar
    No. This will not help. DO NOT DO THIS!! I did this and I have no recovery. Just uninstall your su program from the root-system-app. Then just factory wipe. Press and hold the down+menu+power buttons. (If this takes you to download then remove the battery, replace and do the same except use the vol up bottom. Take your finger off the power button on first vibrate. Chose factory data reset. This should do it!
    Sent from my LG-VS450PP using Tapatalk
    10-14-2014 04:16 PM
  1. The case against DSLRs - Do you need a stand alone camera?
    By JeffDenver in forum General News & Discussion
    Last Post: 11-02-2014, 08:38 AM
  2. Replies: 1
    Last Post: 10-13-2014, 11:32 PM
  3. How do I fix a need root error in Kingo?
    By x7r gaming in forum Samsung Galaxy S5
    Last Post: 10-13-2014, 07:08 PM
  4. Replies: 0
    Last Post: 10-13-2014, 06:03 PM
  5. Replies: 1
    Last Post: 10-13-2014, 05:51 PM
